Hi, The dvd player tray on my TV is sticking.  It seems to have dropped slightly and is fouling the slide down door.  If I lift it slightly with a small screwdriver it opens.  Then closes OK and plays perfectly.  It looks like an easy fix.  How do I open things up to gain access to the mechanism?  Thanks,  John
