Beovision 7 & Beovision 6-26 DTV problems
You need a dish - I too live in a 200+ year old cottage but the dishes these days are really not that big and you can always place them away from the house if necessary. The system is not flexible enough for your plans but you can have multiple boxes and use them independently. You could have a separate Sky box upstairs working as V.Aux and retain control over the main box if you have Sky+ downstairs so that you can watch recorded programmes.
The alternative , if you cannot put up with a dish, is to use a separate Freeview recorder - choose wisely - I believe Topfield are a recommended brand - and the same level of integration is possible. To be honest, I am not sure why anyone gets the B&O module as it is pretty poorly specified. External boxes can be replaced cheaply when new technology comes along and cost a minimal amount compared the the B&O product. The quality of picture would not seem to be an issue.
Peter is quite right, your TV is fitted with a PUC (periferal unit controller) that can be updated with a laptop by any B&O engineer.  This allows a huge choice of STB's including Sky, Freeview & Freesat options.  From a Freeview point of view, Topfield TF5800 or 5810 are good twin tuners with Hard Drive recording.  Sky+ is a very poular choice and for Freesat Humax have just released their Foxsat HD twin tuner 320Gb recorder.  All can be used with Beo4 as long as your PUC is programmed accordingly.
Chaps
Absolutley superb - I will be contacting my dealer next week and insisting on refund for DTV modules then get an alternative freeview solution.  Never even knew it could be done - dealer mentioned nothing about these options!
Thank you for your time.  Rob
Hi Peter,
Can you tell me which STB to select in the B&O TV setup menu when using a Sky+ box?
I had the software in my beovision 7 upgraded about 6 months ago by the dealer, so I'm assuming the sky+ box should be in the long list, but I can't see it.
Thanks,
David
