Beovision 7-55"
Hi again, my current 7-55", frustratingly not 3D, i operate it with a beo6, all set-up as you would expect, the beo6 controls the sky, all ok, but the centre button does not select the program from the sky menu, the ^ and down arrows work great, but to select the program you want, I have to key in the channel, although I didn't buy it from wilmslow, they have been very helpful, i have booked a service call, but before they come round, does anyone know of the problem.
With my 7-55 I have to press the play button after pressing the up & down arrows to select the program
Hope this helps
