BeoNut1 wrote:
At the below link, there are two small jpegs that can be downloaded (I can't figure out how to attach jpegs on these Beoworld forums - I'm not smart enough to do so):
I could not display/view the images on your website ... but as you said they are downloadable !
So I uploaded one of them for you into a folder under my ID called "for Mark D" (let me know if you want it deleted, or the one that includes your child added)
FYI the process is (annoyingly cumbersome) to use two windows, one for manipulating the file(s) and the other for manipulating the post(s):
In the "file(s)" window ...
1. go to your profile (click on your "Signed in as name")
2. scroll down that page to "My Files" and click that
3. on this screen type into the input box the name of the folder you want to store things under e.g. [for Mark D] and click {Add Folder} button
4. click on the new folder's name "for Mark D" in our example
5. click on {Choose File} button ... and then use the popped-up menu/dialogue to select your file on your PC (a Mac I believe) for uploading (IMG_0546.jpg in this case)
6. now press the {Add File} that will perform the upload
7. now click on the uploaded image thumbnail or its link (IMG_0546.jpg) to have the image displayed full-size
8. now right-click on the large image and select "Copy Image Address"
Now in the "post(s)" window ...
9. click on the "advanced.image_desc" (!) icon on the post's toolbar (it is the icon of the photo of a tree) ... and in the popped-up menu/dialogue box do a past of the 'Image Address' you copied into the "Image URL" input area [ ] and press the {Insert} button
10. the image, annoyingly, will not immediately appear in your post, but it is invisibly there and provided you don't type over it the next edit command or add image etc will result in it appearing
