Beovision 7-55 3D
Quick question for people with the new TV. What version of the BS3 firmware is installed on the TV?
Hungedu wrote:
Does anyone out there have any idea of which glasses might work with this TV? They are available through B&O for about $200 each, but I'm sure there are Samsung ones out there for a lot less that are compatible with the 7-55. I just don't want to spend $200 per pair of glasses that one of my friend's' kids are going to drop on the floor and break.
These are not that expensive and they are hard to break. 😁
I'll buy one dozen!
Just got my BV 7-55" 3D. The first one sold and delivered in France! It's worth a picture 🙂
Will try to write a review after the first tests.
Cheers.
What differences are there from 7-55 MKI to MKII (3D)?
This is what I have found out till now:
  • 3D
  • Local dimming in smaller squeares
Any other?
/MikaelB
Looking at the size of the 6000s next to the BV7-55, you realise how big the BV7-55 is.
My dealer's arrived when I was in store and, no kidding, you could fit a small car in the palleted box. I have no idea how they got it in to the store. It was so heavy I couldn't even move it along the floor, myself!
Erm, then I saw this:
Hi Folks,
I just came back from my B&O dealer in order to give a look at the new 7-55 3D. I was surprise to notice a design difference between the 2D and 3D model.
The BR tray is the same size on both, but not the bottom alu frame. In the 2D version, they have the same height, but with the 3D, the bottom alu frame is bigger. You can see it slightly on Griebel's pictures. At first it was not noticeable, but after some time, you can spot this absence of "alignement" in the general shape.
well, it is strange. What's your opinion?
Sergio
Right, of 1,4 cm (0,55 in).
strange. is it for a special purpose or just a change in design?
