I am not an owner of an 7-55 but I have extensively viewed it in a number of different showrooms, and have also heard the Beolab 7-6 and my thoughts as to it's sound are quite in contrast to yours. However, I have heard it (7-6) in an AV movie role with both Beolab 5's and Beolab 9's - not on it's own. This is an important point, because if you pop in a DVD or Bluray and are simply running the 7-6 in stereo mode with no other surround sound speakers in employ - i.e 5.1 or 7.1 surround, the processor in the TV will merely mix down the 5.1 or 7.1 soundtrack to two channel stereo. This will result in noticeable degradation of the sound.
I don't know if this was the case re your audition, but I'd strongly recommend you try it in the context of a surround sound setup and properly level matched etc.
Hope this helps
Best Regards
John.... 🙂
due to the configuration of the room,in which the TV would be placed,and the fact that it also accommodates my(non B & O) hi-fi system,I don't have the space for a surround sound system.
Therefore,the Beolab 7-6 was auditioned as a stand alone stereo speaker.
Given it's cost,I was not overly impressed with it's performance,but this might have been improved by adjustment to the sound settings.
I would also have liked to adjust the Picture settings,as,if as was stated by the dealer they were "straight out of the box",some thing required adjustment.
The opening sequence of 'Gladiator' instead of portraying the gloom of daybreak was more representative of bright sunshine.
Best regards,
Terry.
