BeoVision 7-55----Owner experience?
Beoboiinoz wrote:
I am not an owner of an 7-55 but I have extensively viewed it in a number of different showrooms, and have also heard the Beolab 7-6 and my thoughts as to it's sound are quite in contrast to yours.  However, I have heard it (7-6) in an AV movie role with both Beolab 5's and Beolab 9's - not on it's own.  This is an important point, because if you pop in a DVD or Bluray and are simply running the 7-6 in stereo mode with no other surround sound speakers in employ - i.e 5.1 or 7.1 surround, the processor in the TV will merely mix down the 5.1 or 7.1 soundtrack to two channel stereo.  This will result in noticeable degradation of the sound.
I don't know if this was the case re your audition, but I'd strongly recommend you try it in the context of a surround sound setup and properly level matched etc.
Hope this helps
Best Regards
John.... 🙂
   due to the configuration of the room,in which the TV would be placed,and the fact that it also accommodates my(non B & O) hi-fi system,I don't have the space for a surround sound system.
Therefore,the Beolab 7-6 was auditioned as a stand alone stereo speaker.
Given it's cost,I was not overly impressed with it's performance,but this might have been improved by adjustment to the sound settings.
I would also have liked to adjust the Picture settings,as,if as was stated by the dealer they were "straight out of the box",some thing required adjustment.
The opening sequence of 'Gladiator' instead of portraying the gloom of daybreak was more representative of bright sunshine.
Best regards,
Terry.
A few weeks ago I wrote about replacing an Avant with BV 7-55 w/ BL 7-4.
Most of the signal feed is via satellite and SD. I have not treated myself to much of Blue Ray yet. (My 7-55 is the one without integrated BR player.) However, the picture is outstanding and gives a strong presence. I did not have to adjust color settings, motion blur virtually non detectable.
Decision for BL 7-4 loudspeaker was a practical one as I have BL1s as corner speakers. So far, I am impressed with the "body" and "volume strength" of the BL 7-4.
The size of the TV is quite imposing but once it is set up... you get used to it, especially as the shapes, forms, glass and alu materials make a statement in any room.  I can only recommend to test view the BV 7-55 and then make a decision based on personal preference.
I would buy it again.
I recently had a demo of the revised BV7-55.
The dealer's set up was utilising a BL7-6 as a centre speaker in a surround sound system in which BL3s formed the front R/L speakers.
Both in a surround sound configuration,and as a stand alone stereo speaker,I remained underwhelmed by the BL7-6 which,to my ears, sounded tonally thin.
We then switched a BL7-4 for the BL7-6,and combined it with the BL3s in a 2:1 configuration.
What a contrast-tonally it was richer,and altogether the sound was more involving.
As for the new BV7-55.
The 512 zones for the backlighting LEDs help produce PQ,even  on Freeview broadcasts,that has to be seen to be believed.
The demo was a total disaster,in that I succumbed to temptation,and ordered a BV7-55,with a BL7-4,and a pair of BL3s.😁
The panel on the 55" is the best I've ever seen. Better than my old BV7-40 MKIV. Also proves how much difference the panel makes over the BS3.
Very impressed with the BV7-55".
TerryM wrote:
More than likely,a small,elite group,but I would appreciate it if any owners would share their experience with the BV 7-55.
Any problems with the usual shortcomings of LCD technology,viz motion blur,uneven backlighting,black level?
I have read the FlatPanels review-is the bluish tint mentioned by them noticeable in a home environment(as compared to a showroom)?
Thanks.
I concur with the previous posts - the BV7-55" is a thing of beauty, both from a design point of view and with regard to picture and sound quality, which are clearly above the other B&O models, including the 40" BV7.
It is indeed big, but once you have tasted it, seeing a 40" inch screen makes you miss the bigger size. My 27" iMac seemed huge when I bought it, but there is no way I would go for a 21" iMac now. I love my BV7 55 and would buy one again in a heartbeat if I had to.
VANTAGE
I've had my 7-55 since early August of 2011, and it's been a great TV. Wonderful contrast. The only fault I've seen is in some really dark movies with sparse lighting, you can see a little "cloudiness". This effect is because the local dimming is trying to precisely illuminate just a few places on an otherwise dark picture. Sometimes it's not perfect, but in most circumstances, you'll never notice it.
Sigmund, since the release of the MK VI Beovision 7-40 the CCFL technology has been replaced with LED. The reason for this is the 3D tech works better with LED.
Since my changeover from CRT,because of the inherent shortcomings of LCD technology,I have been an advocate of Plasma TVs,and my four year old Pioneer is still providing excelllent PQ.
However,one of the factors inclining me towards LCD is it's greater clarity ie absence of background dithering noise.
The adoption of edge lit LEDs has introduced a number of problems which have yet to be rectified-even by Loewe on their top of the range TVs.
Even the mainstream manufacturers that have full backlit TVs are experiencing problems with both hardware,and picture,quality.
The BV7-55 has,as far as I am aware,by far the largest number(512) of backlighting zones,so the problems of 'cloudiness' or 'haloing',and non uniformity of back ground lighting should be significantly reduced.
I should have referred to the effect as "haloing". I have the 3D version, which is the most recent generation of the 7-55. The haloing is noticeable in some dark movies, but hardly an issue under most viewing conditions.
Just went from a 7-55 mk1 to the mk2, and I have to agree that the "haloing" is still there - but mainly on SD sources (dark scenes) - but less so than on the mk1. The black level on on the mk2 is outstanding, but what sold me was they grey tones - it does produce a very natural picture. Prior to the 7-55 mk1 I had the BV9 mk2, and the 7-55 mk2 is the first LCD set I have owned that is as "natural" as the plasma.
The speed (for start-up) of the internal disc player is much improved over the mk1, and there are less bugs - but there are some. I would consider a 3. party bluray player if you have the room for it.
I kept the BL7-6 from the mk1, but the sound quality in speaker 1 mode changed to the worse with the mk2. Another funny observation was that this TV is part of a cinema setup, and as the projector is activated the sound will rotate 90 deg and 2xBL4000 are actived as the cinema center. With the mk1, you could tell the drop in sound quality going from the BL7-6 to the 2xBL4000 - with the mk2 it is the other way around... and the speakers and cabling etc are all the same.
The TV changed the "TV speaker setting" to BL7-4 by itself, but even after switching it back to the 7-6 the sound was not as good as with the mk1. Is there something wrong with the BS3 mkIII and the "pre-calibration" for the TV-speaker when the BL7-6 is selected? I suspect so.
But, back to the PQ, this is simply stunning. And the improvement from the mk1 to the mk2 is significant IMHO.
Roger
