BeoVision 7, 50% there...
The color depth maybe another issue, set to high/highest may not work with Beovision. Laat chance....
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
Hi, how do I alter the colour depth? Options I have for AV4 source are V AUX DTV and Pc. All of which work with Audio. Converter is this one:
Color depth needs to be changed on fire tv stick (if possible).
In the reviews it states
It appears to upscale to 1080p, I purchased it for a 720p TV with DVI input and it wouldn't work/wouldn't display due to upscaling
Ahhhh good spot, I will return and get the one above!! Many thanks!!
You can test if it converts if you have a TV set that Displays the Input Format.
For example we use a Panasonic TV as Display for the Beosystem 4.
It Shows 1.080 p / 60 hz if a source of that kind is chosen.
Just wanted to say thanks to everyone who offered up advice, I bought the recommended HDMI convertor and it worked straight away!! The screen occasionally and very briefly fades to black but apart from that I am really pleased with it.
Next challenge is to find a close fitting fixed wall bracket....they seem to be more expensive than the TV they support!! Is there any alternative to the official one?
