BeoVision 7, 50% there...
OK, before i leave this TV out for the bin men, one last attempt....
So i have what i believe is a fully functioning BeoVision 7 Mk 1 with built in DVD player and HD upgrade. I want to use it solely for viewing content via an Amazon Firestick.
My set up is as follows: Firestick inserted directly into a HDMI > DVI convertor. 24 Pin DVI cable out of this convertor into the DVI port on the TV. The convertor also has an audio out which i have liked to the L/R inputs on the TV. Connections wise i have AV4 linked to PC and DVI. No joy whatsoever, blank screen.
As a test to make sure all the above connections and cables are working I have tried replacing the Firestick with a HDMI cable linked to a YouView freeview box (set to 720p). I get sound (great sound!!) but no picture when I do this....so close!!! Any ideas where i am going wrong?
If the two hdmi sources that you have tried (firestick and freeview) have outputs that have High Bandwidth Digital Content Protection (hdcp), then you will not get a picture unless your HDMI>DVI converter also strips the hdcp from the digital video signal.
Perhaps you can find a device with an hdmi output that does not have hdcp - a laptop maybe?
Or maybe go into your Freeview box settings and turn off the hdcp - if that is possible.
(If you have (eg) a PS4, you can turn of hdcp in its menu.)
Or find a HDMI>DVI converter that strips the hdcp, like mine:
I will try...pics to illustrate here:
Thanks for the suggestions. Tried a laptop, exactly the same result, sound but no picture.
According to the serial number it is not hd ready....
Are you sure about the hd upgrade?
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
How about Hertz settings? Maybe you need either 50 OR 60 Hz. Cannot remember....
I have a receipt for 'Fitting Internal HD Scaler Kit & Updated System Software' from Nov 2010. I am hoping this confirms it?
I guess so.
Did you try to use VMEM/VTAPE instead of PC?
I have set Firestick resolution to 720 and tried both 50 and 60Htz.
Please post name of converter you use. Did you try the converter with another TV?
