BeoVision 7-40 MKIII problem with sw 4.12
My dealer updated the sw on my BeoVision 7-40 MKIII from 3.5 to 4.12, now the TV has problems adapting from 4:3 format to 16:9. Before the TV switched between format 1, 2 or 3 automaticlly, however with the new sw it stays on the same format if you change channels. Anyone any ideas?
thanks
Thanks I'll do that of course. I was only wandering if this is a know problem
anyone?
Mine was upgraded to (also from Netherlands); without a problem.
But I still believe the automatic stand should be able to go more to the left (which should be fixed with the upgrade?!).
