Beovision 7-40 mk4 blu ray
I installed a mac mini for a customer about 6 months all seemed to be working fine but he has had issues with the tv, with the DVD which has recently been replaced. I used to work as an installer, but have never seen this fault before. I get no sound from hdmi from the mac sky, even a ps3 connected to the Scart socket (av3) he has the sky linked and is using the Scart (av1) sound is ok on that but if I unplug the Scart, then I get a perfect pict on hdmi but no sound. Blu ray player is ok itproduces the sound. It is plugged into socket D is that correct?? The other thing I noticed the software is old has not been updated I was wondering if that could be the issue, he also says after 25 mins the sound just disappears on DVD and sky he has to switch of then on and it's ok, after another 25mins the same problem. I just wondered if any beoworlders have heard of this issue, not one I have seen before, any help would be appreciated
Kai
Did you try using different HDMI cables? I had to go through two different cables on my own BV7-55 before fixing the HDMI audio issue for good.
