Hello, i am David
Hope someone maybe able to help me, Its a few yrs since i was last on here, i have a problem if anyone has any ideas that i could try out to maybe resolve the problem.
I have a Beovision 7 32 which is fine, all the speakers worked and still do. i bought a used Beovision 7 40 mk 2 for the larger screen. I set it up as you do, is not to hard if your used to the Beovision menu, as i am.
I have come across this unexpected problem with centre speaker, plugged into the cinema centre socket, is a lab 7-4, which i think the tv isn't sending a signal [sound] to, with lab 3's as front with 6000's rear. when i choose sound system on tv menu 1 3 or 5 there is no sound at all from anything, choice 2 uses the lab 3's fine & 4 uses both sets of speakers fine. i think i have done every thing possible to try to get sound out of the tv on the cinema centre socket with no joy, maybe its software update required?
Would appreciate any feedback.. thanks
David
