When I use either the component HD socket or the DVD-I socket to connect sources to my TV together with connecting a cable to the digital sound input Im unable to get any sound. I am selecting the correct option in the menu to match the digital input.
If I connect a source using the scart connection the digital sound works fine.
My software is 6.2. Do I have a fault with TV or do I need to upgrade panel to HD to get the digital sound inputs to work with DVD-I and component HD?
