Hi All,
Does anyone know what the latest SW version is for the BeoVision 7-40 MK V?
Thanks in advance.
Bas
Hi All,
Thanks in advance.
Bas
build 818
h8 is the 10.05a
greetings
Thanks!
If I look in our Service Menu, I see the following:
06 IC3 AP SW8.12a
06 IC2 IOP SW23.00a
Does that mean that we have an older Software version? And do you know where I can find the release notes of the new SW versions?
Greetings Bas
Hi Bas
As i replied in the mail i sent you, the issue will be solved if you have your SW updated. This is a fact now that i also know your current SW version.
So dont worry :-)
/Ehlerz
