Beovision 7 40 MK 1 or 2 Picture Quality?
Hi,  I would like to honestly know what everybody now thinks of the earlier BV7 sets 40" Mk1&2  32" Mk1&2 and if they are worth buying second hand! Or is the picture quality questionable compared to the newer screens of the last 2 years?
Before I give out what I still consider a lot of money for 1 of the above Id like the Beoworlders opinions.
Thanks in advance Douglas C
Go for a Mk3 if you can Full Hd.
I have a BV7-40 MKI already 4 years and still being pleased with the excellent picture quality. I am however not on digital broadcasting, still on analogue cable, asthis is the only option  in our part of town. The BV7 obviously has an superior signal processor which coverts the analogue signal as efficiently as possible. If you are not on DVB or need HDMI or DVI connections, the MKI or MKII is still a good choice. I was thinking changing my MKI with a MKIV, but after comparing both with an analogue signal, I did not see any reason to change.
Regards, Reinhard
Thanks, But as I would like to see BBC HD on Satelite soon and use my AppleTV to its full potential I will have to change my Master TV some time soon . I have 2 Avant  RFs in my system at the moment But HD is knocking on the door! And wondered if the MK1s & 2s would do the job properly as the MK 3s & 4s are still to expensive for me.
Regards Douglas
If the mk1 is update with hd-kit or if you buy mk2 the picture quality is very good
on HD channels, Mk3 and 4 has "Full HD" but its no tv channels that use it (and
not to be in years) because to see the different between HD and Full HD you have
to be less then 1 meter from the screen and all the other Standard channels are
so "poore" quality that you probaly sitting 2-4 meters away right?
Conclusition if you find a MK1/2 to right price buy it !
Regards
Tomas
