beovision 7-40, Masterlink and Sound Delay
well, with a HDMI / SPDIF connection, there won't be any signal distributed to the ML. Therefore we always connect a analog L/R Cinch cable as well. So the problem is solved only by disallow your source the digital output. I think that there should be a solution for this problem, since it's only a matter of software, i guess.(sorry for my poor english...hope you get my point)
@Alsfeld: You are right, the sound delay is not acceptable. I got in touch with Beocare, but they only said " we are sorry that you do not like it". I have the impression that they mean I am talking about a color.
In my eyes this is a clear lack, and we should push B&O to solve it.
I found out, that if I press Picture Mute, the sound is without any delay. As a negativ effect on this I found out, that a Dolby Digital DVD will not be playing in DD, but in Audio mode - which is not thru the Dolby decoder.
It is only a question of software nothing else.
Hello
I am having the same trouble with my brand new BV 10-46, delivered one week ago (October 16th 2010). Has there been any solution for this issue in the meantime?
Thank you very much.
gregorio
