Hello
in the user guide to the above television it states the following
If you disable the TV tuner or DVB tuner, you can activate a connected peripheral unit with the TV or DTV button.
... does anyone know if it is possible to use the TV button to switch a HDMI input on for my Apple TV?
thanks
