You need for more than one HDMI device:
1. a HDMI switch with separate coax sound output plus HDMI to DVI cable plus coax cable for Sound. All devices attach via HDMI to HDMI cable to the switch.
link or similar
OR
2. one HDMI to DVI plus Sound converter (Sound Can be spdif - but then you Need a spdif to coax converter, too).
You connect HDMI Input to your device and and HDMI Output via DVI cable to the DVI Slot. Sound via coax (Maybe converter first…)
OR HDMI to HDMI plus Sound converter (Sound Can be spdif - but then you Need a spdif to coax converter, too). You connect HDMI Input to your device and and HDMI Output via HDMI to DVI cable to the DVI Slot. Sound via coax (Maybe converter first…)
AND one HDMI to component (green, blue, red) plus Sound converter Sound Can be spdif - but then you Need a spdif to coax converter, too). You connect HDMI Input to your device and and component Output via componet cable to the componet slots. Sound via coax (Maybe converter first…)
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
