Beovision 7 32inch
Hi everyone just a quick question,recently purchased Beovision 7 mk3 32inch JUNE this year, just got the correct leads to connect to my Blu ray player, cheers for the advice on that one, but i can only view the movies in 1080i, when i change the definition to 1080p the screen goes blank? any ideas.
Cheers Paul.
The 7-32 does not have a 1080p panel - did you think it did?  720p is superior to 1080i, I would go for that selection personally.
LOL, fair point!  I think beauty is in the eye of the beholder - if it floats your boat at 1080i then go for it, progressive scan image will always (technically) be superior to an interlaced signal (source dependent I think!)
