Beovision 7-32 MKIII
Hi al. Have jost got this TV. There are new chasiss insyalled, and works nearly OK😕
I always turn off 230V to the TV, and when I put code in (when I turn on the TV) sometimes TV short after
turn off by it self, and then I can' turn ON TV by remote, and I must wait 1-2 minutes, and then I can Torn ON V by remote, and TV works OK until next day.
Do someone have an idea ?
The TV is fully updated, and flash updatet to use DVI for DVB TV.
Per
Check if you really need PIN protection - could possibly be a condition of your insurance to get a discount.
If PIN protection is not needed  - disable it.
