I have just obtained a Humax HD-Fox T2 'Freeview' box to use with a recently acquired BV 7-32 Mk3 TV. I have connected this to 'AV2' using HDMI to DVI for picture, and scart-to-scart connection for sound - all works as I think it should, and the HD picture is actually very good.
However, the problem is that I have to firstly use the Beo4 to turn on TV, then the Humax remote to select the channel, and then back to the Beo4 to alter the volume - which frankly makes the process of watching TV casually a bit of a chore.
Previously the Humax box was connected to a Panasonic TV (via HDMI, admittedly...), and once this TV was switched on the Humax remote could be used to control BOTH the channel AND the volume. I'm presuming the scart connection from the Humax doesn't send a signal 'understandable' to the 7-32 to allow it to alter its volume in the same way...
This chopping and changing between remotes is driving me daft, so my question is: Would connecting the Humax in some other way (i.e. AV3 via phono leads?, SPDIF to A1?...), allow me to control both the sound AND channel with the Humax remote?
By the way, the Humax box is not in my PUC table, although the Humax Foxsat HDR is... but this doesn't work, as I hoped it might! So at the moment I can't use the Beo4 to control the Humax; any comments on whether I can get the PUC table updated for this particular box welcome.
I hope I have explained my problem clearly enough - I'm still quite new to B&O, so forgive me if I'm overlooking something obvious...
Thanks in advance for your help.
