Beovision 7-32 DVI
Question is:
Is the YPbPr socket an Option? Converters from HDMI to YPbPr are available.
Or what about using a HDMI HDCP remover to feed the DVI-I socket?
I have the same issue with Beovision 7 40 MKI (not hd ready), trying to connect a HDMI source...
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
@kallasr - didn't you notice my links above?
Sure did, very good background information.
So, it does work, using a YPbPr converter?
See also
I did not try the '...to component' converter.
Haven't got the opportunity to/the gear for this experiment.
But - as atated - I have the '...to scart' converter.
I am quite sure it will work.
How good it works, will depend on the quality of the converter - don't expect too much of a cheap conveter-thing.
On the other hand don't expect too much from a non HD-Ready tv!!!
If I had a 7-32 (non HD-Ready) I would go for the HDFury-solution - even if I had to use 'PC' from 'List' to activate it (just put it to the first place in the 'List').
Note: using a converter always means 'downscaling' - that is exactly what is needed to get things to work.
I don't think you need to downscale.
If the native/provided resolution is 720p (which is fine for me), the TV should be able to handle it:
The panel resolution is 1.366 x 768.
So, too be more precise: I want to display 720p material, what is the best way to do this?
Thanks again for your support!!
Ralf
Many people in Denmark are using new (MPEG4) DVB-C/DVB-T2-receivers nowadays on their 'old' bv's.
Me too Erm..
I have installed quite a few 'new receivers' using a simple scart cable, and the picture was always improved to the earlier analog signals.
I am not sure that it is worth the effiord to handle with different converters/extra cables just to get a (theoredically) slight better picture.
But judge for yourself, when you have tried different options - and do let us know what you think/see.
Just my experience/opinion 🙂
P.S. And save the 'converter-job' for things with pure/only HDMI-output such as the AppleTV-box?
This little box worked!
I can now watch Netflix via a Smart BlueRay Player on my BeoVision 7 MK1!
Enjoy!
And which box/which solution did you end up with?
