Beovision 7-32 Cooling fans
riverstyx wrote:
Hi Mindphaser.
You mean you have the BL7.1 placed on the floor and the BV7 balanced on top of it?
If so I would be more concerned about it falling over or airflow being restricted than any potential problems with dust. There will always be a build up of dust on the fan blades (and indeed the rest of the fan) over time, as well as a gradual build up of dust within the TV but this rarely becomes an issue unless severe.
Many thanks for the answer riverstyx :)
Well, the BV 7 - 32 is on top of the BL 7.1 ....but is NOT balanced on the flor 'cause it's placed against the wall with the Walla Bracket Typ. 4095....originally it was shippped with it :)...i bought the BV 7-32 second hand, as i previously specified.
So, time for moving as fast as i can from the Wall Bracket Type 4095 to the Motorized Floor Stand 4091 !
PS: in case i would like to CLEAN those fan blades, would be it a difficult operation?
Thanks again,B&O still rules for me !!!
Anyway, here is the extract of the 'Changing Cooling Fans' from the service Manual of BV 7-32 (actually, Mark III)
http://cloudsix.me/jpmivhk1dpcd/Beovision_7_32_MKIII_Fan.pdf
Seems pretty smiple, anyway i'll try to clean'em first :)
Good evening all,
just wondering: are these BV 7-.40 cooling fans
http://www.ebay.it/itm/Einbau-DVD-Player-fur-BeoVision-7-40-Type-9361-B-O-Bang-und-Olufsen-o-k-/301772578265?hash=item46430c1dd9:g:5E8AAOSwA4dWJQr6
Compatible with the BV 7 -32 (MK III ) ?
The really kind seller from eBay.de answered at my question:
I am sorry, but there are two different items. The fan-dimensions for BeoVision 7-40 and for BeoVision 7-32 are not the same.
Hi Mindphaser
Do you have a problem with your fans are are you just concerned they might have got dirty? Unless they have either stopped working (in which case the BV7 will display 'fan error'), or they have become noisy, I wouldn't worry about them..
Kind Regards,
Martin.
Hello Riverstyx,
no, never had a single fan-related problem so far with my BV 7-32 (also 'cause i use it maybe 3-4 hours a week :) ) .....my questions were just for...FANATISM !😎
