Beovision 7 -32 inch PCM problem possible solution
Fellow members,
                        I have just been posted this from the B & O website by a chap called Herrn.  I will contact my dealer tomorrow and see if it is the way forward.  Here is the reply i got from him>>>>>>>>>
Herrn Dirk Henkel
link Posted 19/5/2007 4:43 PM (#15964 - in reply to #15524)
Subject: Re: Beovision 7: Having problems with Digital Audio? Then read this ...
Quote Reply Alert
Hi Mr. Carl, PCM calls "Pulse Code Modulation" or LPCM for "Linear Pulse Code Modulation". The Systems NTSC and/or PAL absolutely needed the PCM (2 channels). A new SW, I mean "Software (7.5)" is now available for the BV 7 to solve this problem Nr. 8 ! Your Dealer can it be update via PUC (or STB)
Kind regards, Dirk
lets all Hope this solves the porblem guys.
Regards
Carl Sheerman
Hi Carl,
Does a software update resolve the problem?
Best,
Toby
