Beovision 6 won't turn on HELP!
Hi,  I've purchased a Beovision 6 type no 9202 which is faulty.  The red standby light comes on when plugged into the mains but the TV won't power up.  If I switch on the mains supply while pressing TV on a beo 4 remote the light changes from red to green but then goes back to red.  The Beo 4 is working fine with my beovision 7 and all my B&O stuff so is OK.   I've also tried it with a Beolink 7000 but no success.  Any suggestions to get this working welcomed.
Bye,  John
Try changing the V.OPT to 2, maybe it's in option 0??
Hi could you solve your issue ? I have a similar problem
