Beovision 6 Type 9250 Update the PUC List
Hello,
I have a Beovision 6 type 9250 (the first one). SO the PUC List is from 2003. Now I want to use a DVB-T Receiver from Skymaster (DT 500) and later the Technisat Digipal 2. How can I upgrade the PUC List because there is no possibility to connect the screen to a computer. The only connection is the Beolink and systemlink. The dealer wants to have 100€ for updating the list.
On the homepage of skymaster is the information they use the ir-code 0656 and 1165.
The picture shows a few of the supported receivers.
It can only be done by a dealer because effectively it's a software update.  Perhaps ask if he can drop the price - especially if you take the TV to his premises.
Make sure that you 'future proof' the TV by adding all the STBs that you can think you may use in the future!
Why I don't get this software from the B&O page? It must be possible to do it self.
Only the latest B&O TVs (BV11, Avant etc) allow you to download the codes for new set top boxes.
I had mine reprogrammed for £25, but that was from a 'second life' B&O dealer from whom I was buying the TV.
you can try the TEC. Digital PK for the Technisat Digipal, this might work because TEC. is the abbreviation for Technisat in the PUC / STB List.
Now I have the Digipal 2 and it works.
Please select "TEC Digital PK" as your Receiver.
Now everything is fine.
