Puncher:
Unless its "full" HD (1080) I would want to use a 23" or 26" HD panel as a computer monitor - 768 lines is basic 17" monitor resolution - blowing that up to 26" would be unacceptable for me for normal monitor use.
As an aside, I've been shopping for a combined bedroom TV/computer monitor for my son. As far as I can see no one sells a 26" panel with full HD resolution (as explained above this is more for it's role as a monitor than a TV) although some will accept a 1080p signal and downscale it. There are 22" sets that have 1050 lines and so aren't quite full HD but will make a decent monitor - these also have picture in picture and picture against picture (i.e side by side) and include Freeview tuners. These can display PC input and TV simultaneously using the PIP modes. It must of course accept an HD signal as the next present is to be a PS3!
If a B&O isn't a possibility, then I see a lot of people using Samsung LCD TVs as computer monitors as well. Very good picture too! Sony also offer a really good 20" with 1 x HDMI, 1 x Component, 1 x VGA, 2 x Scarts & an RF input for both built in analogue and digital (Freeview) tuners. The Sony is IMO, the best TV under 26" excluding a B&O...
Yes the 20"" Sony MFM-HT205 is a good alternative 1690x1050 WSXGA 1600:1 contrast and 470cd/m2 and 6ms.. ! With double lamp panel instead of one it is true bright and good for PC like my Sony VAIO laptop.. And it have a very good RF decoder as well ...
Regards
