Hi Guys,
Can anyone enlighten me as to the difference between the BeoVision 6-26 and the BeoCentre 6-26?
Which is/was the more expensive?
Paul
Hi Guys,
Paul
Hi Paul,
Probably easier to read about the differences BV6 v. BC6 yourself on the products page.
In case you havn't been there before, just click on the Main Site at the top, go into products, and select them from the drop down boxes.
I'm pretty sure the only difference is the inclusion of a radio in the BC6, and you paid more for the privelidge
Wrong.
The last bv6 where a much better set with HDMI and an improved panel.
Follow the advice in bentleymans post
To pre-empt any confusion.
BeoVision6 26 was originally launched with a fabric loudspeaker grill. When the set had a radio tuner fitted and became BeoCentre 6 the speak grill was aluminium.
Subsequently the radio tuner was removed and the set reverted to the BeoVision6 pre fix however retained the aluminium speaker grill. It is worth taking note as unless you know which version of BeoVision6 you talking about, the age and specification will be wildly different.
Opman
New bv6-26 are now about(boxed) for around £1700 - no stand or remote though
tony
Asked the same thing about Beovision 6-22 VS Becenter 6-23 months ago
...for sure the Becenters (the 6-23 and the 6-26) were (way) more expensive than their Beovision counterpart;and apart of DAB radio and different panel,also other colours were available !
I'm an owner of a Black/Aluminium 6-22; and you know what?
I find the
well thanks a lot guys - I had a look Bentleyman at that info page - thanks.
very interesting. Reason i ask is that I have beoCENTRE 6-26, and i paid Euro 4950 in May 2008. I wanted a TV for my bedroom, but cos im linked, i can access the radio and CD's on my Beosound 9000, so in fact i have never played the in-built radio. i also access the DVD on my BV7-40 through it when i want to watch a DVD in bed!!
Its a bit disappointing in terms of not being HD ready - after all, at that time in 2008, every piece of S*** on the market was HD ready or full HD.
I have it in my bedroom and use Beolabs 8000's as additional speakers. it sounds really good. Im just wondering (maybe naively!!lol) why I was not offered the BVision 6-26 at 1/2 the price. I guess it would have done just as good a job, but with the bonus of a better tv in the BV26?
probably my own fault though, as I probably saw it in shop n just said I wanted one and didnt better explore the options open to me. To be honest, at that time, i was not aware of distinction between BV 6-26 and BC 6-26.
stll, i feel a bit of regret i spent almost 5K on an 'average' TV.
Paul
To add to this, the original Beovision 6-26 had a 15:9 screen and was not "HD-ready". The replacement, Beocentre 6-26, had a proper 16:9 screen, was "HD-ready" as standard ( DVI ), and could be fitted with a module of choice, radio ( FM or DAB ) or Freeview tuner, and therefore more expensive. The final incarnation, Beovision 6-26 again, dropped the radio options but had Freeview as standard plus of course the much needed HDMI. To add icing to the cake, the final production units were heavilly discounted, but of course "when the've gone the've gone".
Neil.
