I am trying to get the serial number, etc. of my Beovision 6-26. How do I bring this data up on the TV screen? Thanks for your help.
Beovision 6-26 Serial Number
Just remove the back fabric grille. Pull it forward gently. The Serial Number is under there 🙂
Lee
PS - If you've got a later 'aluminium grille' BeoVision 6 just slide it left to release and pull it forward gently.
Many thanks Lee.
I understood that by pressing the right button(s) on the B&O handset the serial number, etc. can be shown on the TV screen.
You have to Press MENU and then MENU 0 0 GO then you Can find serial nummer service counters and other info, just don't change anything😊
Søren
Many thanks Soren, It works.
Noel
