Beovision 6-26 lost pin - a write off?
I bought a use Beovision 6-26 some years back and got the pin from the seller on a text. Have been going through my old iPhones with no luck. Is it a write off or are there any way of getting it reset?Seems a pity just to write off this beauty but it will be a lot cheaper to buy a used replacement than getting it by a B&O service.
Just phone your dealer. He can provide you with a master-pin to unlock the BV6.I bought a use Beovision 6-26 some years back and got the pin from the seller on a text.Have been going through my old iPhones with no luck.
I had a simular situation when I bought a second hand one (cheap).
Thanks, will do that.Just phone your dealer. He can provide you with a master-pin to unlock the BV6. I had a simular situation when I bought a second hand one (cheap).
