Beovision 6-26 DVI-I
Ok...for anyone in the know.  I'd like to hook up my Blu ray player using the HDMI to DVI connection and the analog left/right analog audio outs.
On Beophile description of the connections on the back of the BV 6 26...it says that there is a DVI I + right/left audio.  Well, I can find the DVI connection, but I can not find the audio ins?
Anybody know where I can look for them?
Thanks!
Guy
Hi beoguy
As you look at the connections from the rear the phono sockets are discreetly tucked in on the left handside along with the component video inputs. The are listed as AV3. You will then need to assign the socket accordingly.
Hi, First ? What model/mark BV6 do you have?
Well I have found the Audio in for the DVI connection.  So my thoughts are to use the HDMI out from the Bluray to a DVI-I connector for the BV.
Although...what I'm reading online is that there is copy protection signals that are sent through the HDMI that if not received and sent back as OK, it won't play the disk.
Has anybody done this with succuss?
Guy
