I have installed a DVB-T module (not HD) into my Beovision 6-26/Type 9272 according to the “mounting instruction for DVB module kit 1404220/1446600”. I only couldn’t carry out the last step of the instructions which is “for Beovision 6 only, use ServiceTool to update to M2 SW 4.0 or higher”.
When searching for channels the module doesn’t pick up C22 at 482.0 MHz and I am therefore missing all the BBC TV channels and radio stations. All other channels are recognised without any problems.
When connecting a Panasonic TU-CT20 Freeview box via the STB controller C22 at 482.0 MHZ is found with nearly maximum signal strength and I therefore rule out that the issue is related to aerial/reception.
For Monitor Information, DTV Service Menu and Module Information see video clip.
http://www.facebook.com/video/video.php?v=10151029305766333
Does anyone know if the missing software upgrade would solve the issue and if the ServiceTool software can be downloaded anywhere?
