HI,
I am trying to set up a Beovision 6 for my elderly relative. I think about 2006 so not sure it would have DTV integral then. I did email a shop & they implied it might/probably has but not enabled.
These B&O are very alien to me (I can set up pretty much anything tech)
When I next visit I would like to me more informed, I had a quick go but did not get too far.
It has DTV button but shows all the digital sources not channels or guide, I guess that's what they are.
TV setup it scans but did not find anything, this seems to be just analogue I assume.
I tried portable TV & that found all the channels OK so know they are there.
Is this likely to have DTV, if so how do I scan/set up the channels.
Is there an option to enable, Options did not seem to have anything like that but as I say was a little short on time then.
If not, is there a good option for freeview (No satelite) I think before they moved it was set up with Sky & the sat co-ax cables are still hanging around. This must have been connected via the scart I assume.
As no HDMI not sure best option.
Can the scart from a DTV tuner go into the TV, it goes into the master box which has 2 scart sockets.
The shop said probably needs analogue output, I guess he means via the co-ax but that must be a really bad idea (perhaps he meant scart). Can I not get an standard freeview box (as long as it has a scart!) and plug into one of the ones in the master controller box.
There is also the master controller with CD & I can see the two B&O OEM sockets & where they GO into the box OK.
Sorry bit vague, If I had more time I would have understood its layout a little better.
Thanks I/A
