You could also check the STB list on your BV6
If you look in your PUC list/STB controller list you will see the various models of STB it can control. Whatever is in the PUC/STB list can be controlled by the Beo4 with a cheap IR cable from the TV to the STB.Does it list any Humax Boxes at all? You might not have to go to the expense of the oneremote solutions
I use a Humax PVR-9300T, with my old BeoVision 5. the Remote seems the same as the one for the PVR-9200T I had before!
PS if it will control HUMAX boxes
Devon,
UK
