Hi guys currently got a older model beovision 6 22 just wondering if a humax box will allow me to control set top box using beo4?i rang up b and o and this said too old to be upgraded eg stb list however as it does have some older model of humax stb listed on the stb guide on the menu list on tv and i was thinking would a newer humax box still work if exact model not listed,I just want to be able to control a stb box using my beo4
Beovision 6 22 and which humax freeview box which will allow beo4 use?
Take a look in the archive forum.
I'm fairly sure that Keith at some point found that a lot of Humax boxes shared the same codes.
You could also check the STB list on your BV6 and try to source an exact STB via eBay.
Graham
Cheers yes tried ebay but these boxes listed on tv are about 10 yrs old and unable to get models around this date
What kind of stb box do you need? Cable- satellite-, dvbt receiver...?
I have some satellite boxes that can be controlled directly via Beo4 - with built in Beo4 chip - no puc necessary.
They are Humax and Digiality (Scart connection, no HD TV).
Stefan
Hi Stefan,
Just a freeview box do not need HD,not a sattellite just one that I connect my aerial to and picks up UK freeview!That would be great if you any a box with it already biult in for beo4 remote!
And scart socket only needed !
Sorry, my boxes are satellite receivers.
But the link to oneremote might help. They make Scart cables with builtin Beo chips. So the scart connected box will be controlled via scart pin 8 through your Beovision. Oneremote are also selling cable boxes with this chip.
http://shop.oneremote.dk/catalog/index.php?cPath=15_16
You can also contact Ulf. www.ulf-kiener.de
He makes a chip for stb boxes. He already did some modifying/customizing work for me. You can send him a box, and he will make it Beo-controllable.
His chip is great.
Good luck
Stefan
Great thanks for that !
Hope this works with uk boxes ?
