Beovision 5 (non HD) and Amazon Fire TV
Hi all. I have had the Beivision 5 unit for some time now and have experienced the frustrations of tech moving with the times. I have used Apple TV via a Keene scart converter for example for years.
But recently I decided to give the Amazon Fire TV a whirl but even via a HD video converter I seem to struggle to get it to work.
is anyone else succeeding with this?
Am I using the right or wrong converter?
thanks
alvin
So the apple tv hdmi connection via the scart converter works, the fire tv one not?
Did you try to set the resolution of the fire tv to 720p (using a minitor or other tv set with hdmi input)?
I used an active hdmi to s-video converter from ligawo to connect a fire tv stick to a Loewe CRT.
So there is a solution for you for sure.
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
I use one of these connected to the side panel (composite connections)
http://www.amazon.co.uk/gp/product/B00NGHAPBI?keywords=hdmi%20converter&qid=1457688578&ref_=sr_1_3&sr=8-3
I notice it's listed as currently unavailable, but there must be something v similar out there. I use it for my amazon fire stick and it works well. I do get a bit of a 'buzz' at high volume but otherwise it's good! The problem I had when I installed it was picture and no sound-it was solved by connecting the box to the mains electricity by the included usb adapter plug. So far, it's worked well enough for me to hold of purchasing a newer Beovision!
