BeoVision 5 / Control Swisscom box
Hello fellow beoworlders,
A friend have a BeoVision 5 - 42.
He would like to control a Swisscom box with his Beo 4 remote control.
Swisscom box data:
Swisscom model kmm3010-SCB
S/N..KF30SOH1DXXXX
MAC ID 00-1E-6B-XX-XX-XX
SAP 1253XX 0
I can see that with STB-SW Central Europe 4.06 there is a box named SWISSCOM blue-win.
Does anybody know if we can control the beforementioned box with this SW or some other solution.
Best regards
BMGHB
I know what Bluewin is... but we don't have the TV yet so no idea !
Sorry.
Good to see that there are some others in Switzerland here...
Anyone else here who would have an idea???
Allo Luke,
Actually im from denmark but my friend lives in switzerland.
What is bluewin?
BMGHB
I Have the Bluewin Box from Swisscom, with the Beovision 7-32. You can take the STB SWISSCOM Blue-win, it works fine.
Bluewin TV is digital-TV over IP.
Hi Postman,
Thats sounds promising. Would you mind flipping the box over and check it is indeed the kmm3010-SCB box?
Thx in advance :)
BMGHB
Wow i just check'd there are three models they distribute at the moment. So far any of the ones we hook'd up with the PUC work'd fine. But i can't tell you if we really use'd all of them yet ๐Ÿ˜•.
I will hook one of those up within the next two weeks. Afraid i can't give you an advice yet.
It is the KMM3010 Modell. All Swisscom Boxes using the same Remotecontrol.
Good to know and what i've expected, thanks.
Thx Postman๐Ÿ˜
Register to access the forums, reference material, and exclusive member benefits โ€” including our monthly prize draw.
