the Lintronic will receive B&O infrared codes from the remote control and send the proper LG code to the TV.
The reason for the RCA/Phone >> Dual SCART is the following.
Pressing Beo4 "TV":
- Will turn on the BV5 (which does not know its got a new screen). The BV5 TV tuner will turn on
- Lintronic will turn on the LG TV and switch to the VGA input.
Result: I will be able to get the native TV menu for connections, stand setting etc. on the screen and change them if needed.
Pressing Beo4 "DTV"
- BV5 will switch to Scart socket AV2. It will only receive sound from the LG.
- Lintronic will switch to its build in TV tuner as source.
Result: Volume Up/Down will be handled by the BV5. Lintronic will handle all needed IR commands to control the LG TV
Pressing Beo4 "V.TAPE"
- BV5 will switch to Scart socket AV3. It will only receive sound from LG (that is the reason for RCA >> dual Scart)
- Lintronic will switch to LG HDMI 1.
Result: A raspberry pi with KODI media center is connected to HDMI 1. Volume Up/Down will be handled by the BV5
Pressing Beo4 "DVD"
- BV5 will switch to Scart socket AV1. It will operate a Beocenter 2 (with DVD) via masterlink / scart
- Lintronic will switch LG to VGA to receive the native picture from the BV5. Just like the Panasonic plasma screen would have.
Result: Hopefully a decent picture via VGA..... If not... I might connect the Beocenter Scart to the LG Scart and reprogramme the Lintronic to select that socket instead.... We'll see.
In theory... that should work... Hopefully I will know by end this week.
I also need a way to get access to the CI+ slot of the LG TV. So I might have to cut a hole in the BV5 chassis.
Keep you posted.
