Beovision 4 Setting up hd..... this display does support hdcp
Hi I have a beovision 4 type 9324 which I am told is HD, I bought a hdmi to dvi Lead and connected it to my if sky box and the message "this display does support hdcp"
anyone got any tips for setting HD up?
Try this:
I don't have that option in the 00 menu
Is the Sky Box connected to the monitor or to the Beosystem?
Sounds as if you are going directly to the screen. In which case you will need to find a Beosystem processor. The Panel itself doesn't handle the HDCP process, the processor does.
Monitor
