BeoVision 4 power on without BeoSystem
problem fixed :)
BV4 is playing from my laptop just nice :) via VGA input
It is not full HD but 720p i think 1366 x 768 Pixel
Picture is briliant as plasma should be.
Ii's Panasonic TH-50PH9 monitor. Beovision model 4-50 Type 9021 serial : 202....
Next i hope can bring it to life via HDMI input.
Hi everyone,
I have the same problem, I just purchased a Beovison 4 65 - type 8991 with a beosystem 2 but without cables.
I do not even know if the beovision work since I cannot turn it on, I try with some panasonic modele using my logitech harmony but dit not manage yet.
Do you have any advise such as panasonic plasma modele, location of the ir sensor on the 4 65, things I could check,...
Have a good day,
Loic
Update: problem fixed also on my side thanks to this post.
I remove the back of the tv to understand, I was happy to see a red ligth inside and I finally understand the location of the IR receiver, it is in the back at the vertical of the supports that allow to fix the beovision to the wall stand.
Using the logitech IR blaster and the "driver" for Panasonic TH-65PHD, the TV switch ON!!!
Next step, hdmi to vga for beovision with audio extractor SPDIF for bose lifestyle.
What a screen!!
Hi Cclr.
I am about to purchase a Beovision 4 65 with a beosystem  2 same as you. Type 9091, item 1819663 serial 21417656
I would like to be able to use It as a Televisión controled by Chrome Cast or FireTv.
I see you have turned It on using a "Panasonic" remote control that is helpfull to be sure que TV screen works fine.
I assume maybe I will need to buy a beosystem 3 have you found any other solution?
Hi Cclr.
