Hi everyone,
I have the same problem, I just purchased a Beovison 4 65 - type 8991 with a beosystem 2 but without cables.
I do not even know if the beovision work since I cannot turn it on, I try with some panasonic modele using my logitech harmony but dit not manage yet.
Do you have any advise such as panasonic plasma modele, location of the ir sensor on the 4 65, things I could check,...
Have a good day,
Loic
Update: problem fixed also on my side thanks to this post.
I remove the back of the tv to understand, I was happy to see a red ligth inside and I finally understand the location of the IR receiver, it is in the back at the vertical of the supports that allow to fix the beovision to the wall stand.
Using the logitech IR blaster and the "driver" for Panasonic TH-65PHD, the TV switch ON!!!
Next step, hdmi to vga for beovision with audio extractor SPDIF for bose lifestyle.
What a screen!!
