BeoVision 4 power on without BeoSystem
Dear friends,
I have just bought a BeoVision 4/42 plasma panel alone to connect with my PC.
The seller assured me that it powers on automatically when detects an incoming VGA signal, and now I know that is not true. I have read tons of manuals and docs over the internet and have not found a solution.
I understand, that BeoSystem send a signal to Serial Port to control it power state. Can it be simulated or called by something else?
Please help me understand how can I power on plasma without BeoSystem.
Thank you!
Lots of infos on this site if you are a silver/gold member.
The service manual shows this:
(BV4-50-D8_service-eng.pdf)
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
Thanks a lot!
Now I need to find a remote.NDo you know the model of the Panasonic plasma which is inside?
Can you please provide me a model name of your remote?
oleg
What is the resolution of your 4-42?
It sould be something like TH-42P...
- PW for wide screen (852 x 480)
- PH for HD (1.366 x 768)
- PF for Full HD (1.920 x 1.080)
Just check the panasonic website for details. Look for professionla plasma display.
I used to run a TH-42PWD6 (as far as I remember) with a Beosystem 2.
Ralf
PS: a list I found that I used while searching for a display
Full HD TH-42PF20 2010 G13 1.920 x 1.080 Px        2.073.600
Full HD TH-42PF11 2008 G11 1.920 x 1.080 Px       2.073.600
High Definition TH-42PH20 2010 G13 1024 x 768 Pixel           786.432
High Definition TH-42PH12 2009 G12 1024 x 768 Pixel           786.432
High Definition TH-42PH11 2008 G11 1024 x 768 Pixel           786.432
High Definition TH-42PH10 2007 G10 1024 x 768 Pixel           786.432
High Definition TH-42PH9EK 2007 G9 1024 x 768 Pixel           786.432
High Definition TH-42PD12 2009 G12 1024 x 768 Pixel           786.432
High Definition TH-42PHD8 2006 G8 1366 x 768 Pixel     1.049.088
Standard Def. TH-42PS10 2007 G10 852 x 480 Pixel           408.960
Standard Def. TH-42PG9 2007 G9 852 x 480 Pixel           408.960
Full HD TH-50PF20 2010 G13
Full HD TH-50PF11 2008 G11
Full HD TH-50PF10 2007 G10
High Definition TH-50PH20 2010 G13
High Definition TH-50PH12 2009 G12
High Definition TH-50PH11 2008 G11
High Definition TH-50PH10 2007 G10 1366 x 768 Pixel       1.049.088
High Definition TH-50PHD8 2005 G8 1366 x 768 Pixel       1.049.088
High Definition TH-50PD12 2009 G12
High Definition TH-50PHW6 2004 1024 x 768 Pixel           786.432
High Definition TH-42PHW6 2004 1024 x 768 Pixel           786.432
Standard Def. TH-42PWD6EX 2004 852 x 480 Pixel           408.960
Thank your your help!
I have ordered a remote, so I will inform with a result when it arrives!
Oleg
So you can put it on ? please tell me details
thank you i have de same problem with a beovision 4 full hd  type 9080 fro 4 -2008
ok i have two remotes from panasonic tvs but i can not put in on with this 50 " beovision 4 next step for me is remove the aluminium frame
also i have another  37 " beovision 4 but in this the panasonic remote is working
any new idea is welcome
thank you
that is an old topic but... i just opened BV 4-50  and find out that is just nice packed Panasonic TH-50PH9 display plasma.
Now the problem..i connect PC i can only see part of the desktop as it is in ZOOM mode :( and can only connected via VGA port.
I did try to connect via DVI to HDMI to my computer ..but no luck..dark screen
And i can enter menu on TV but no option to set the picture correct.
Any hint to fix that ?
I
TH-50PH9 display plasma is HD ready only, so be sure to feed the right solution with your PC. And the right Hz (50, I guess). Do you have a Panasonic remote to control the screen?
Ralf
