I have a BeoSystem 3 and a BeoVision 4 65" Monitor controlled by Beo4 Remote.
I need to "lower" the picture on the screen to eliminate frame bars.
Can someone tell me how to get to the "geometry settings" using the remote?
Thanks for your help. It seemed to be such a simple problem, but as you both suggest I'll need to give the dealer a call.
