Beovision-4 dvi resolution problem
My tv is woring fine when watching regualar tv. But when I use the installed dvi-port on the screen with a mac mini there is a flickering bar / vertical line in the left side of the screen. Other than that the picture is fine.
When changing resolution the flickering disappears on some resolutions:
1366x768 flickering
1344x756 flickering
1280x720 flickering
1024x768 works without flickering but the picture is stretched
1024x576 flickering
800x600(stretched mode) flickering
800x600 flickering on right side of the screen
640 x 480 flickering
The strange thing is that when I connect my macbook to the same cord and the same mini-dvi-to-dvi-adapter that the mac mini uses there is no flickering at all no matter what resolution I pick.
When I connect another mac mini or apple tv the flickering is back.
Seems like mac mini´s graphics card is not compatible or is sending out some strange frequency that disturbs the screen... ?
Any other people that have used the same setup ?
don't know if it works or not but it's no harm . try switch everything off , switch on mac mini first , then switch on TV . when i first start my apple tv , similar problem occurs .
I did that, and still the left flickering bar is appearing. The funny thing is that it dont appear until the login screen shows up.
Anyway, it dissapeared for some reason randomly a while ago so I am sure it will be handled soon.
anyway, please look at my other thread, the no-sound issue is really bugging me
/forum/general-discussion-and-questions/endless-beosound-moment-issues-please-help#post-2130553
Still having this weird problem
When I boot up the mac mini I see the grey screen and the apple logo without any problem.
When I enter the blue screen and later login, there is a artifact on the left side of the screen about 5-10 pixels wide which is changing colours rapidly on each pixel / line
I think I can rule out any kind of interference since it works on some resolutions.
It seems to be related to aspect ratio since 800 x 600, 1024 x 768 works but all other which is not 4:3 is giving the artifact.
Is there some kind of setting I can change, maybe in the screen settings for beovision-4?
If there is a similar setting / program on the mac mini help is really appreciated
Since it oddly dont appear on when connecting the macbook to the beovision screen I am really scratching my head here...
