Beovision 4-65 use with beosystem 4
Can you tell me how to make the cables?
the rs232 to rj45 cables i need to make so i need the wiring scheme.
the HDMI to dvi is a simpel connector
and do you have any idea ik and how to connect and wire the Beostand connector to a Beovision 7-55 floorstand?
i am planning om putting my Beovision 4-50 on a beovision7-55 floorstand and so it would be fantastic to be able to rotate the stand.
thanx for the help
i am planning om putting my Beovision 4-50 on a beosystem 4 and put it on a beovision7-55 floorstand and so it would be fantastic to be able to rotate the stand.
2 the HDMI to dvi is a simpel connector, am i right?
thanx for the help
Best regards
Luuc
Sorry wrong thread. Can’t seem to delete.
so the question is:1 the cables from the beovision from rs232 to rj45 cables i need to make so i need the wiring scheme. Could you help me with that part?What colors need to be on which pin?2 the HDMI to dvi is a simpel connector, am i right?
thanx for the help
Best regards
Luuc
hi, maybe this helps.
I have a similar task.
But I do not understand one detail...
... RJ45 to DSUB9 male.
DSUB Pin 5 is GND - but does not go to any PIN in the RJ45?
Even though RJ45 has Blue GND but on Pin 4....?
Thanks in advance!
Ralf
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
