kai wrote:
You need it to be option 1 to this press list and red dot together you should get the remote saying something press till it says option then press 1, you should see the ur blink if it does that should you. If you do not have a red dot on the ir then it might be wired wrong
Translation:
Press the LIST button and the STANDBY button (the red dot at the bottom right hand corner of your remote) at the same time.
The screen on the remote controller should read: 'ADD?'
Press LIST twice until 'OPTION?' appears, then press GO
The screen should now be flashing 'V.OPT'
Point the controller at your IR receiver, then press number 1 (the red light should blink at this stage in acceptance of the command)
Press TV on the controller
If the set has not started up this time, then you must have a connection problem elsewhere.
One other thing to check - is the BeoSystem 2 actually on? It can be hard to tell! There's a red button at the top - push this - you should hear a clicking noise inside as it boots up.
