Could anyone please confirm the height of a BeoVision 4 103" on the motorised stand? The figure I have is 211cm from the bottom of the base to the top of the IR eye. Is that correct?
BeoVision 4-103 dimensions
The dealer page with dimensions quotes 212cm.
Regards
Opman
Excellent. Thank you! Take it that's the top of the IR eye and not to the top of the screen? In that case, it should fit — with millimetres to spare.
If you can afford a BV4-103" you should be able to afford raising your ceiling as well! 😂
/Dennis
/Dennis
The roof of the Bat Cave is really hard to chisel out!
Excellent. We need a picture when it's in situ!
Thankfully this is something I thought about, during construction...
I shall do my best to photograph the whole installation. It will be quite interesting, as it's going in a penthouse.
I have now had an official response from Bang & Olufsen: in the viewing position on the motorised stand, the BeoVision 4-103 is 212cm to the top of the screen and 215cm to the top of the IR eye. If anybody knows differently, please let me know!
Cannot wait to see the installation progress !
Congrats politcian !
