Beovision 14 the end of Bang Olufsen Tv
Thanks for sharing your thoughts. This is helpful.
Eclipse is not an option for me as it indeed looks too much like a LG televison pieced together with a soundbar. I know the arguments that it is not, but visually it does not do the trick for me.
The BV14 visually is best for me as it has the wooden grill making it superior in design to the BV11 or BV7. I am thinking of 55", so 4k may make a difference.
The absence of the "curtain" is a big deal though. Some people may laugh now, but it is a part of what makes B&O unique. Really a pity that B&O got rid of it.
Would I even notice that this is Android based if I only use the ATV? I thought the ATV GUI may be all I see in this case and I would never ever need to see that there is a Android somewhere in it?
How does googlecast and NL work with the BV14? Are they part of Android? What and how is albumart displayed when casting via googlecast or NL to the BV14? Can I cast via googlecast or NL when the BV is turned off (i.e., some sense-in that allows to turn on BLs when casting, while keeping the screen off)?
Thanks again for sharing your thoughts.
The wood lamellas are able to fit a BV11 from mk2 onward
Would not give me 4k (less critical) and also no integrated googlecast. If I were to use a googlecast dongle, it would not auto-switch and I would need to turn on the TV manually if I were to cast audio to it.
The 11 has a better panel / screen technology than the 14. I had the 14, and I cannot stress enough how the 14 struggles with dark scenes.
I loved the design and look of the 14, but in the end picture quality is still the most important thing.
Also the sound is a bit more punchy on the 11.
And 4k without HDR is marginal at best. I watched some 4K netflix on the 14, and the big issue was still the poor dimming on the 14, much more so than extra resolution.
I swapped the 14 for an Avant pretty Android - it's a much better panel.
Edge lit TV'S can be better than backlit ones.
You are right - curtains are only missing on WebOS which is the OS moving forward as I can gather.
Glad to hear it is working for you. How about issues with responsiveness when navigatig the menues on the Android platform? When I have tried the platform on Avant NG or BV14 it was noticeable. Perhaps it has been fixed since then.
I never had any complained about the responsiveness on my BV14 but I did notice however increased responsiveness in the latest firmware update a few weeks ago which was a pleasant surprise.
Karel.
Yes, it's easy to forget the BV14 has an old 4K panel missing many key features such as HDR.
One thing I don't like about my BV11 is the speed from pressing the remote to showing a picture. Takes far too long. Almost twice the length as the BV12.
Try owning an Avant!  You press "TV" at kick off, and you're almost guaranteed to catch the second half ❓
wow. Sometimes I think I musn't have pressed the remote, the BV11 takes so long to show a picture. BV12-65 is much faster!
I changed the times on the Avant so it’s quicker to startup when I get up
I have the times at 6 am and after 9 I think from memory
