Hello
I got my BV14-55 and I am very happy with it. When fed 4k video I think the image is just amazing! I paired it with a Nvidia Shield PRO 4k which means I'm not too bothered with the fact that B&O hasn't updated the internal OS from Android 5 to 6. Android 5 only supports FAT32 formatted external USB drives so that + Netflix app was the main reason for getting the Shield, but since I have found more good use for the Shield. The new Shield 4k Pro + PUC works just fine in case anyome was considering that.
After first week of ownership I have 3 questions I hope someone here can help me clear up :)
1) I can't get the BeoRemote App to work on my iOS devices. I tried iPad and iPhone. I tried creating a 5ghz network so I am sure they are on same frequency. I tried re-configuring dns, subnet etc manually, but the app never sees the product. Is the App not compatible with BV14? Anywhere I can reach the dev-team?
2) I have a set of Beoplay H9s which are paired via Bluetooth. When I turn them on the audio from the TV goes to the headphones - just like I want it. But what do I do in case I want to use my headphones for something else and then later connect. I can't find a "Send audio to" option on the remote where I can manually switch between audio playing audio from the TV or H9s. I can go into bluetooth settings and re-connect there but that is several keypresses.
3) I have a set of Beolab 5 which are connected to a soundcard with digial-out, so it's not a part of my B&O eco-system.I turn it on by pressing Radio on an old Beo4. On my new Beoremote One BT I can get it to turn on by pressing Music and then "Beo 4 Audio", then "Radio". But then I am switched out of Beovision 14 mode. Question: Can I while I am in "Beovision 14" mode get it to send the Beo4 Radio command?
