shouldnt be a contradiction hopefully - i may have expressed it poorly.
The Avant Mk 1 used a different panel to the Avant Mk 2 / Horizon / BV14 - changing from edge lit panels to backlit / globally dimmed panels. As i mentioned yesterday, i believe the newer panels to be a bit of a step down.
As for choices, its not easy i agree - have a think about what's really most important to achieve.
For me i had to weigh up losing the 14 design vs gaining a better screen on the Avant MK 1 + more stable software - and am happy with the choice.
I didnt have any reflection off the frame issues with my 14, which was near a big window - so i wouldnt worry about that too much. And the 14 is quite the design statement, which the Avant doesnt come close to.
But in the end, design while important was secondary to primary functionality - preferred PQ and software OS to me. That would be my advice - go for the PQ and OS you prefer. Is HDR and / or 4K much of a factor in your decision (?) etc etc.
You wont find much support on here for the Android BV's - regardless of how many forum members have actually lived with one of them or not, the litany of initial software problems, their slow resolution and the slightly worse panel choice meant many just steered well clear of them.
And the Eclipse, while strongly spec'ed and relatively free of the software issues that plagued the 14, has been divisive and a can of worms. Personally i dont mind webOS, not my cup of tea aesthetically, but generally regarded as the best TV OS - shame there wasn't some B&O sheen applied to it.
You could consider a Loewe Bild, but while they're elegant, they're also no great shakes design wise - others seem to have had success in integrating one into a B&O sets without too much difficulty, so there is that option.
